Autolevel and autocontrast erratic
Postby gregglee on Thu Feb 02, 2012 10:43 am
I just can't get autolevel or auto contrast to work consistently or really even correctly. Before I take a couple hours to put together examples with images and histograms at multiple settings, I thought I'd just describe it to ask if others are running into this.
I have already turned this in via surveymonkey with example raw files, but that's a bit of a black hole, with no system in place to assign a case number or to report status.
I am a Bibble5 Pro user. But this issue is definitely more than fine tuning from Bibble to ASP. It seems like a bug slipped in during the transition.
With Bibble, autolevels worked most of the time. (meaning no adjustment required) It rarely works with ASP because:
ASP autolevels responds irregularly and unpredictably to clip percentage changes. Starting from .001, then incrementing by .001, nothing happens for one to many increments, than at some point one additional .001 causes a large change. At what value this occurs and the maginitude of the change depend on the image content. Then additional increments produce no further change until the value reaches the next order of magnitude, then eventually another jump change. But by then adjustment is outside the useful range, so just an exercise in checking behavior. Basically ASP autolevel is either on or off with a trigger point and magnitude that varies by image. On the other hand Bibble autolevels responds incrementally to each adjustment to clip percentage, which I see as correct behavior.
So with Bibble I was able to find clip levels to set in camera default that worked most of the time. With ASP the inconsistency makes that impossible.
Auto Contrast (with autolevel off) is a similar situation. Smooth response in Bibble, big jumps in ASP. In addition, in Bibble autolevel and auto contrast produce similar results. In ASP they are rarely similar, with ASP auto contrast frequently throwing the histogram well off the right side compared to autolevels (far to bright in other words). So in ASP auto contrast is rarely a good starting point.
Perhaps related, highlight tool seems more prone to produce the infamous color band artifacts in ASP than Bibble. And this is especially true if highlight and autolevels are used together.
Gregg Lee
12 miles from Glen Rose, Texas
camera equipment
gregglee
motherboard: asus m4a87td evo
processor: amd 1090T
Video Card: nvidia quadro fx 1800
sound_card: on board
Hard_Drive_Capacity: 7 TB
Monitor/Display Make & Model: viewsonic vb2365WB + LG 1933TR portrait
Re: Autolevel and autocontrast erratic
Postby claudermilk on Thu Feb 02, 2012 10:48 am
IMHO autolevels sucks now and is completely useless for the reasons you have pointed out. I've just stopped using it & manually adjust my endpoints. Hopefully this will be fixed in the next release.
Bibble transplant
claudermilk
Postby Tadjio on Thu Feb 02, 2012 1:07 pm
I too have been struggling with AutoLevel but initially thought it might be as I am new to Bibble/ASP.
My comparison is with Levels in PaintShop Pro (PSP).
My first reaction is that 0.200 is far too high as a 'default' setting.
Surely there must be a way to set it lower for all images as a starting point?
I experimented and found that 0.002 has no effect at all but 0.003 upwards does.
I find AutoLevel too harsh and aggresive - it seems to be either on or off without any subtlety.
With PSP Levels I can set my Options to 0.01% Threshold for Histogram Clipping and it works very well in Auto mode.
It then displays where the resultant settings are (in the range 0 for Shadows to 255 for Highlights).
For example it might suggest Highlights at 208 and Shadows of 4 whereas
in ASP the same image looks terrible and blown with a setting of 0.2, is mediocre at 0.02 and unchanged at 0.002
All this testing is not helped by the poor handling of Highlights in ASP.
I find that Perfectly Clear is likewise harsh and aggresive.
Tadjio
PSP X6 user
AfterShot Pro ASPirant
Canon EOS 550D & Olympus E-PM1
Windows 8 64-bit Pro
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Postby afx on Thu Feb 02, 2012 1:27 pm
Tadjio wrote:My first reaction is that 0.200 is far too high as a 'default' setting.
Yup, something like 0.02 is much more sensible...
This is set just like any other image default...
I think the general idea of autolevels is broken by design....
Use autocontrast as a start and go from there.
cheers
afx
The AfterShot Survival Guide
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Postby Tadjio on Thu Feb 02, 2012 4:25 pm
afx wrote:I think the general idea of autolevels is broken by design....
cheers
afx
I got quite excited for a minute and tried Auto Contrast.
I couldn't see how it got its parameters and so read the Help system:
help wrote:AutoContrast — click this button to set the output white and black points based on image content.
It uses the AutoLevel values (highlight and shadow) to perform a one-time adjustment to increase contrast.
The main difference between this tool and AutoLevel is that the output white and black values can be more easily adjusted than the AutoLevel values.
I screen dumped the Tools Panel of the Curves Histogram for both AutoLevel and AutoContrast and they appear identical in PSP, as verified by doing a 'Subtract'.
AutoContrast vs AutoLevel
Back to the black board as it seems that AutoContrast is also "broken by design" :cry:
Tadjio
PSP X6 user
Tadjio
sound_card: Sound
Postby gregglee on Thu Feb 02, 2012 7:54 pm
What does that mean? (Other than you agree that AL is broken.)
afx wrote:Use autocontrast as a start and go from there.
My experience is that auto contrast is more broken than auto levels.
And if you "go from there" (I assume this means adjust the sliders after AC), what is the point of doing an extra AC step? Just adjust the sliders.
Gregg Lee
camera equipment
gregglee
Postby afx on Thu Feb 02, 2012 11:47 pm
Tadjio wrote:Back to the black board as it seems that AutoContrast is also "broken by design" :cry:
Nope, you did not get the difference.....
Autolevels is continuously adjusting the histogram, so it can interfere with other image adjustments.
Though AS now has it earlier in the pipeline than Bibble, making it less messy, it still is a continuous auto adjustment.
Autocontrast adjusts the histogram only once. And then you can tweak it from there as it conveniently sets the levels handles (the little triangles at the bottom of the curves tool).
This is a huge difference.
gregglee wrote:And if you "go from there" (I assume this means adjust the sliders after AC), what is the point of doing an extra AC step? Just adjust the sliders.
It is significantly faster. Often enough no further adjustment is needed or only one for the triangle needs to be moved after pressing AC.
The only thing missing is a hotkey for autocontrast....
cheers
afx
afx
System_Drive: N/A
Postby roland65 on Fri Feb 03, 2012 1:22 am
Congratulations! You've found a bug in ASP. I tried the same autolevels manipulation and went to the same conclusion : this tool is completely buggy for now!
The question is : how can we report this bug to the dev team? By means of the Bibble forum? Or is there another way?
Anyway, I come from the Open Source world and I didn't ever see a situation with a so bad user support. Hey Mr Corel, where are you? How can we get in touch with you?
RB
roland65
Postby fcoiffie on Fri Feb 03, 2012 1:33 am
I confirm also that AutoLevel and AutoContrast are broken in ASP.
I used to use it in Bibble5 and ASP has absolutely not the same behaviour (and of course, even if the same values for levels) : the effect is really too strong.
fcoiffie
processor: Intel Core2 Quad CPU Q6600 at 2.40GHz
ram: 6 GB
Video Card: AMD Radeon HD 2400 XT
Monitor/Display Make & Model: Sony Trinitron
Postby thufor on Fri Feb 03, 2012 3:34 pm
Indeed, both seem to be broken. As if the functionality was applied to too small image in the mipmap... If this is the issue the fix should be trivial.
thufor
System_Drive: B
Postby gregglee on Fri Feb 03, 2012 6:32 pm
Not my experience, but could well depend on camera and image composition.
Gregg Lee
camera equipment
gregglee
Postby gregglee on Fri Feb 03, 2012 9:26 pm
roland65 wrote:The question is : how can we report this bug to the dev team? By means of the Bibble forum? Or is there another way?
I reported it on Jan 17 using https://www.surveymonkey.com/s/ASPFeedback
More reports might help the ranking.
Gregg Lee
camera equipment
gregglee
Postby Jeff Stephens on Fri Feb 03, 2012 9:54 pm
More reports are not necessary. We're aware of this; it is not trivial to fix, but it is on our radar..
Cheers, Jeff
Jeff Stephens
Corel
motherboard: several
processor: Opterons and Atoms
ram: Bunches
Video Card: something cheap
Hard_Drive_Capacity: pretty big
Monitor/Display Make & Model: several
Postby gregglee on Fri Feb 03, 2012 11:34 pm
Jeff Stephens wrote:More reports are not necessary. We're aware of this; it is not trivial to fix, but it is on our radar..
Cheers, Jeff
Thanks for some feedback.
Certainly it is not a trivial problem. It's a serious bug in a basic function.
But it is not obvious why "it is not trivial to fix." (I assume that means "It is difficult to fix.") It worked well in Bibble, so it would seem like the solution is known.
I am uncertain what "it is on our radar" means. Are you aiming the missiles for launch, or watching to see if it turns and goes away.
Gregg Lee
camera equipment
gregglee
Postby Tadjio on Sat Feb 04, 2012 12:00 am
Cheers, Jeff
Thanks for your input, Jeff.
It is reassuring to know that you take this issue seriously enough to post yourself
as well as the fact that you are reading and responding to our discussion :)
Tadjio
PSP X6 user
Tadjio
sound_card: Sound
