AfterShot Pro RAW+JPEG [or can I sort/filter by Type?]
Re: AfterShot Pro RAW+JPEG [or can I sort/filter by Type?]
Postby andysalay on Mon Jan 23, 2012 12:06 pm
hannes_hab wrote:(sort)/filter can be done in file system mode too:
- go to a raw file you have not edited yet
- set the green "picked" flag
- settings -> save as raw (or camera) - default
thats it - all your new downloaded raw files from CF/SD card have the green flag - the jpgs don have it
you can do ctrl R - to apply the default settings to older images ...
It is a nice workaround, but, it did not move our feature request into useless area, because this workaround blocks natural usage of flags (Pick/Reject). We need these flags for what they were made for.
Regards
Andy Salay
EDIT: typos
andysalay
operating_system: Linux
System_Drive: Z
motherboard: ASUS P5E WS PRO
processor: Core2 Quad Q6700
Video Card: AMD Radeon HD 6670
Postby ChrisC on Mon Jan 23, 2012 12:08 pm
That's another great solution. I was not sure whether the raw defaults get applied during download or only during import.
ChrisC
motherboard: Intel HM65
processor: Intel Core i7
ram: 8 GB DDR3
Video Card: AMD Radeon HD6770M
sound_card: Beats Soundsystem
Hard_Drive_Capacity: 750 GB
Monitor/Display Make & Model: HD+ High-Definition LED HP BrightView Display
Postby afx on Mon Jan 23, 2012 12:11 pm
ChrisC wrote:That's another great solution. I was not sure whether the raw defaults get applied during download or only during import.
Download does not apply anything.
Import and viewing them the first time in the file browser will do it.
cheers
afx
The AfterShot Survival Guide
afx
System_Drive: N/A
Video Card: FirePro 4900
Postby ChrisC on Mon Jan 23, 2012 12:12 pm
andysalay wrote:It is a nice workaround, but, it did not move our feature request into useless area, because this workaround block natural usage of flags (Pick/Reject). We need these flags for what they were made for.
I agree that we nevertheless need some native support in ASP for this situation.
But if you don't like to use the 'picked' flag you could instead use one of the color lables.
ChrisC
ram: 8 GB DDR3
Postby ChrisC on Mon Jan 23, 2012 12:14 pm
cheers
afx
So one needs to import the images into a catalog anyway?
ChrisC
ram: 8 GB DDR3
Postby rawshoter on Mon Jan 23, 2012 12:17 pm
But if you export those Raws as Jpeg or Tiff into the same folder, as I do usually, the Jpegs will get that same flag to. :wink:
rawshoter
processor: Dualcore
Video Card: ATI - 1GB
Postby Fraenzken on Mon Jan 23, 2012 12:28 pm
You can create a preset that deselects the flag. And then apply this preset in the output batch queue.
Fraenzken
Monitor/Display Make & Model: IIyama ProLite E1900S
Postby grubernd on Mon Jan 23, 2012 12:50 pm
ah, those were days when RAW+JPG were treated as one..
after initial rename i just dump the JPGs into a subfolder..
if i let the camera create them, that is.
output is kept separate from the RAWs, anyway.
grubernd
System_Drive: G
Postby rawshoter on Mon Jan 23, 2012 4:26 pm
Fraenzken wrote:And then apply this preset in the output batch queue.
Thanks for the useful hint, Fraenzken. I didn´t thought on that part.
rawshoter
processor: Dualcore
Postby -cr on Tue Jan 24, 2012 3:37 am
Great tip, thanks!
(Although I never bother with JPEGs, anyway, when RAW is available. :)
-cr
System_Drive: Z
Postby ChrisC on Tue Jan 24, 2012 4:02 am
After afx's hint I am not sure if this is working as expected!
> If you still need to import the images to apply the default RAW settings then you can simply use the file type info of the Metadata Browser!?
ChrisC
ram: 8 GB DDR3
Postby hannes_hab on Tue Jan 24, 2012 6:54 am
I think afx meant "viewing them the first time" applies the settings - not downloading ...
You can see the green flag when going to the place where your images are.
No need to import to the catalog.
Try by yourself ...
and - shure - its only a workaround -
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon coolscan LS 2000 with Vuescan
bibble 4, bibble 5, ASP mostly Suse Linux 11.4, sometimes WIN XP
hannes_hab
System_Drive: Z
motherboard: Asus Pundit II M3A320
processor: AMD Phenom II X4 925
ram: 4GB DDR2
Video Card: ATI Radeon HD4550 512MB
sound_card: SBx00 Azalia + ATI R700 Audio Device
Hard_Drive_Capacity: 260GB
Monitor/Display Make & Model: LG W2442
Postby ChrisC on Tue Jan 24, 2012 7:39 am
I did a quick test with existing images. I set a blue label to a jpg and saved this as the rendering default. Browsing other folders with jpgs did NOT show the blue label. Only after CTRL+R (Apply default settings) the label shows up.
and as you said:only a workaround
What I am interessted in is: what would be your prefered feature to support your workflow?
Staking the RAW and jpg? Would this be enough?
When I shoot RAW and JPG I do this only because sometimes the jpg generated from the camera is a perfect reference that I hardly achieve. Otherwise I would only shoot RAW.
So my workflow needs a step where I have to decide whether the developed RAW or the JPG is the one to keep.
ChrisC
ram: 8 GB DDR3
Postby grubernd on Tue Jan 24, 2012 8:26 am
i never mix output from RAW and JPG if it can be avoided.
the look, rendering, sharpening, structure and so on of the image just wont match unless you use software made by the camera manufacturer. and not even that is a guarantee. since i currently use cameras from three companies that is out of the question. also i have yet to see an JPG out of a camera that i am really pleased with. i use JPGs, yes, but i dont like them.
i shoot JPG exclusively for workflow reasons - quick deliveries on sight where there is no time to adjust and render from RAW is my most common usage. a colleague who does 360° panos has to shoot so many images to get the 360° with full dynamic range that he very often shoots jpgs because HDR is maxing the dynamic range anyway and he can fit more locations on a card while shooting.
PS: the Ctrl-R behaviour is by design - otherwise changing your defaults would mess up any image you look at. even those that were done before the new defaults.
grubernd
System_Drive: G
Postby Tadjio on Tue Jan 24, 2012 8:28 am
ChrisC wrote:When I shoot RAW and JPG I do this only because sometimes the jpg generated from the camera is a perfect reference that I hardly achieve. Otherwise I would only shoot RAW.
Before I got AfterShot Pro, I shot in RAW+JPG because my Canon JPG Images (with Picture Styles applied) very often don't need much further editing and so there was no purpose in using Canon's DPP for RAW Conversion.
Now with AfterShot Pro of course the RAW Conversion is much easier but I still have to apply more editing to improve the Sharpness and Lighting, so it is often easier still to start with the JPG.
When I want to adjust Exposure, Highlights, Shadows, Noise etc., I still start with the RAW Image.
Tadjio
PSP X5 user
AfterShot Pro ASPirant
Canon EOS 550D
Windows 8 64-bit Pro
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Previous
