AfterShot Pro - Wishlist for future versions
Re: AfterShot Pro - Wishlist for future versions
Postby jknights on Mon Jan 16, 2012 11:25 am
winston wrote:Remove the 30MB limitation with tif files. ASP could also be a very valuable tool in an analog-hybrid workflow ...
cheers,
Bernd
+1.
We will need to examine removing this limitation for all file types with the new cameras that are just released or about to be released. Their RAW files will blow that easily.
Still learning after all these years!
jknights
operating_system: Mac
motherboard: Apple
processor: Intel 2.33GHz Core2Duo
Video Card: ATI Radeon X1600
sound_card: Intel HDA
Hard_Drive_Capacity: 160GB
Monitor/Display Make & Model: Apple Display
Postby grubernd on Mon Jan 16, 2012 12:22 pm
knutbert wrote:I'm wondering why no one else asked for Wacom support so far, but I would really like to have pressure sensitivity when applying adjustment brushes..
Additionally I would love to have an option to show the master file. In Apple Aperture I can press M to see the original.
wacom pressure sensitivity would be nice (even if i work pretty well without it already)
please define "original" with a raw-file. ;)
the random defaults that the developers chose?
your own defaults? hit Ctrl-R, then undo
the state the file was in when you started the session? hit Ctrl-Shift-R, then undo
grubernd
operating_system: Linux
System_Drive: G
Postby TotallyFred on Mon Jan 16, 2012 1:30 pm
I would love:
Grad filter (like the grad filter pro plugin in Bibble)
Expanded and well maintained lens correction database (distortion and CA) or some internal tool to easily create lens profiles
Fixed highlight recovery (no magenta anymore please)
Engine that does not overdo the mid tones or blow up highlights
Improved external tool handling (something that could export a stack to photomatix)
Improved layer and selection UI
Lightroom plugin compatibility (esp. Nik Software plugins)
EDIT (just thinking):
iPad support
Printing improvements (UI similar to the rest of ASP)
Re-arranging tools in right toolbar
Dockable layer window
Cataloging offline pictures
Large TIFF support (for panoramas)
Thanks in advance and good luck with ASP!
TotallyFred
System_Drive: Z
Postby RickHeath on Mon Jan 16, 2012 3:55 pm
Something to add to the bug list - I added a bunch of output batches but can't get the list to expand to fit the Batch Output window. I can make the window bigger (sometimes :? ) but the length of the list remains the same (complete with scroll bar).
Also if the Batch Output is pinned & I switch to File System the size of the pinned window changes back to its default size (although it does return to the adjusted size when I switch back to Output). It stays the adjusted size if I switch to the Library tab.
Regards
Rick.
RickHeath
Postby bobbert on Tue Jan 17, 2012 6:56 am
This is a great start, and eventually I'll end up using ASP as my DAM. BUT you need to have ASP recognize .PSPIMAGE files created in X4 or I really cannot figure out a workflow. There are good filtering and keyword tools, but ASP has to be better integrated with X4.
bobbert
Postby OldRadioGuy on Tue Jan 17, 2012 11:00 am
RickHeath wrote:Something to add to the bug list - I added a bunch of output batches but can't get the list to expand to fit the Batch Output window. I can make the window bigger (sometimes :? ) but the length of the list remains the same (complete with scroll bar).
Regards
Rick.
Rick, did you report this to Corel? If not, please do at https://www.surveymonkey.com/s/ASPFeedback
Bob
Aftershot Pro; DxO Optics Pro 7; ACDSee Pro 6; PSPX5 Ultimate; Sagelight 4.3; Xara Designer Pro 7; Olympus OM-D E-M5 m4/3 camera
OldRadioGuy
motherboard: Dell 0YJPT1 A00
processor: Intel Core i7-3770 3.40 GHZ 8 virtual cores
Video Card: AMD Radeon HD 7770
sound_card: Realtec High Definition Audio
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Samsung 23" HD 1920x1080 px
Postby quadrox on Tue Jan 17, 2012 12:55 pm
My personal wishlist, ordered according to priority:
1) Improved stability and better debug logging.
AS crashes/freezes often, and the debug log indicates nothing at all as to what happened. 64 bit arch linux system.
2) Bibble style Color Labels
The color labels in Bibble were really useful because it was very easy to see what image had what color label, because the entire background square for that image had that color. In Aftershot the color label is a tiny detail, and it is very difficult to see color labels at a glance. I want the old color labels back, and if I could define my own colors and color labels that would be even better.
3) Albums
I would like to be able to create albums. Think of albums like a normal folder, but instead of actually containing the image/version like a regular folder, the album folder contains references to images/versions already stored in different folders. For example, for a vaction that lasts several days I will have one folder containing pictures for each day. But to make viewing easy I will want to create an album containing some photos (but not all of them) from each vacation day. And when I make an adjustment to one of the photos, this adjustment should naturally be immediately visible in the album as well.
Another use could be an album that contains all pictures of architecture. Or an album that contains the favorite pictures. The possibilities are endless.
I realize that a lot of this can be accomplished using keywords, but for some things it would be great to have a quick solution that doesn't require adding a separate keyword and then searching for it later.
Alternatively, this could work if one could save metadata searches. So if I chose to display all images that have one or more specific keywords, let me save that search for future use and give it a name (similar to saved searches in thunderbird, if you use that). This could be a great way to work with albums.
4) Advanced metata search
It would be nice to be able to make advanced keyword or metadata queries. Something like "All images with keyword landscape and keyword lake, but not the keyword ice".
5) Re-arranging metadata structure
As my collection grows, I sometimes realize that I placed a given keyword in a bad spot in the hierarchy. It would be nice if there was an easy way to move the keyword to a better location in the keyword hierarchy which automatically moves the keyword on all the photos where it has been applied.
6) Multi-Monitor support
In order to work well with several displays it would be nice if all panels could float and could be moved to a different location. Right now I can sort of make-do by stretching the window across two displays, having the browser and thumbnail panels on the left screen and the image and tool panels on the right screen. More customizability would be better though.
7) JPG+RAW support
Make bibble understand that a given JPG+RAW file belong together, and let the use chose how to display them (RAW only, JPG only, both...).
8) Convert to JPG option
I prefer to work with RAW images, but some of my images really only have memory value and are technically completely uninteresting that I don't want to waste too much disk space on them. For these it would be nice to have a fast option that converts the image to JPG and then replaces the RAW image in the catalog with the converted JPG image. I know it would be a dangerous feature, but I would like it nonetheless.
I am sure that I missed some stuff, but this is a good start.
quadrox
motherboard: ASUS P6T
processor: Intel Core i7 920
ram: 12 GB
Video Card: AMD Radeon HD 5870
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: DELL U2410
Postby RickHeath on Tue Jan 17, 2012 1:46 pm
OldRadioGuy wrote:Rick, did you report this to Corel? If not, please do at https://www.surveymonkey.com/s/ASPFeedback
Bob
I hadn't done, but have reported it now.
Rick.
RickHeath
Postby Dulak on Tue Jan 17, 2012 2:14 pm
Hi Guys,
I think,
1. layers need to bee repair, must to work much better than now!
2. ASP alvays must to work very quickly because of RAWs are getting bigger!
Best regards
Artur
Dulak
processor: Pentium Dual Core E5300 2.6GHz
Video Card: GeForce 9400GT
Postby thazooo on Wed Jan 18, 2012 7:59 am
Several items I'd like to see :
Have the option to list several External Editors rather than just one. I use PSP X3 and PP X4 on different images. Be nice to select either in ASP.
Ability to read Grey Scale images. Have many from my scanned negs.
Ability to read files over 30MB. Have image files and some panos that go over this limit.
Dana
thazooo
motherboard: Msi z77a-p43
processor: I5 2.93Ghz
Video Card: Asus ENGT430
sound_card: Asus Xonar
Monitor/Display Make & Model: Dell 2208WFP
Postby kick on Wed Jan 18, 2012 9:02 am
Hello,
Excuse me for my bad english :( .
I would like :D :
1- Synchronization auto of the directory of the hard disk with catalogues or visualization by marker to signal a non-synchro catalogue.
2- Have the possibility of moving only the viewing window to a second monitor, taking into account the latter's icc profile.
3- View any type of files (documents PDF, images, and videos) to the taguers, and then read with the external application of its choice.
4- Filter display JPG + RAW, RAW, JPG images.
5- When no GPS receiver, have the possibility to write the coordinates and altitude.
6- Manager of the keywords: the best opportunity to have a function for sorting alpha-digital by btn click right mouse for example. The worst by drag-drop without this generates a copy.
7- Possibility to choose the path of registration of the presets, keywords.
8- Management of larger files (panoramic).
9- Possibility to choose the location of the cache.
kick
processor: i7 2720QM
Video Card: Quadro 3000
Postby nigelgunn on Thu Jan 19, 2012 8:54 am
Ken Berry wrote:As far as I am aware, all of the Corel programs on this website have been exclusively PC until now. It has only been since the unexpected (to us Site Admins -- Corel never gave us any warning :roll: ) launch of ASP that we have equally unexpectedly become PC, Mac and Linux. We are endeavouring to adjust the registration form, but will require a little more time to do so.
Since when has PC meant Microsoft OR Windows?
nigelgunn
System_Drive: Z
Postby df on Thu Jan 19, 2012 10:04 am
nigelgunn wrote: Since when has PC meant Microsoft OR Windows?
Um, like, for a while man.
https://www.google.com/search?q=mac%2C+ ... 33&bih=774
Regards, Dan
df
sound_card: onboard sound
Hard_Drive_Capacity: 4.5 Tb
Postby kaymann on Thu Jan 19, 2012 10:59 pm
The ability to Roll/UnRoll stacks without having to deselect/reselect.
The ability to Roll/UnRoll all stacks with one keystroke (current work around is to "Ctrl A" select all, then "Ctrl Shift K" Roll/UnRoll.
kaymann
motherboard: ASUS P8P67 PRO REV 3.1
processor: Intel i-7 2600K
Video Card: NVidia GeForce GTX 560 Ti
sound_card: Onboard
Hard_Drive_Capacity: 3T SSD HDD
Monitor/Display Make & Model: Dell 2470
Postby Rob Greenstein on Fri Jan 20, 2012 3:03 pm
Some sort of an processing graphical indicator or message, to reflect that an adjustment to the image is still being rendered. The message or indicator should disappear when the rendering is finished.
Last edited by Rob Greenstein on Fri Jan 20, 2012 3:58 pm, edited 1 time in total.
Robert S. Greenstein, Esq.
Entertainment Industry Business & Legal Affairs
Greenstein Law Offices, Woodland Hills, CA USA
● AfterShot Pro & PaintShop Pro X4 Ultimate
● Canon EOS-1D Mark II N
● PS CS 5.1, LR 3.6
● NIK Software
● DPP 3.11
Rob Greenstein
motherboard: ASUSTek Computer INC. LITHIUM 1.04
processor: 3.00 GHz Intel Pentium D
Video Card: ATI Radeon X300_X550_X1050 Series
sound_card: Hauppauge WinTV PVR PCI II [26xxx]
Hard_Drive_Capacity: 2.135TB
Monitor/Display Make & Model: HP f2105
PreviousNext
