| View previous topic :: View next topic |
| Author |
Message |
moonwalker
Posted: Sun Aug 16, 2009 8:33 am Post subject: dvdws2 menu animations not moving/animating |
i been using dvdws2 for a long time without any problems, exept now for some reason when i import an animation gif file eg: text ,and place it in to the menu screen it appears as a still image after i press play to preview it , and it also has a black colour around it where it should be clear ,
it all works good when i burn it to dvd , it just not displaying correctly while working on it .
before i used to import a gif animtion weather it was text or an image that was moving i could preview it and it would animate as it should . but not now , any help please on what could be causing this .
thanks |
| Back to top |
Coral
| Back to top |
moonwalker
Posted: Mon Aug 17, 2009 9:50 am Post subject: |
i have 2.232 . it has no other update yes ?
that link u gave me isnt the problem i am having , its actual gif animations i import that dont work .where before they did , and the animations that come with the app also dont move when they are in the menu window . |
| Back to top |
Coral
Posted: Mon Aug 17, 2009 4:47 pm Post subject: |
| moonwalker wrote: |
My problem started when I updated from v2 to any other update patch.
Whenever I use animated backgrounds in chapter menu backgrounds the animation will not work.
When I went back to V2 all returned to normal. But lost the option to choose Auto Add Chapters > By fixed intervals. The only solution for me has been to update to V2.232 and load the motion backgrounds manually. |
| Back to top |
sjj1805 Site Admin
Joined: 26 Jan 2005 Posts: 13920 Location: Birmingham UK
Posted: Tue Aug 18, 2009 2:57 am Post subject: |
Tru updating your Direct X
Please click here --> so that we can then view your system specifications. _________________ Regards, Steve Jones, Web Board Administrator
| Back to top |
Coral
Posted: Tue Aug 18, 2009 8:40 pm Post subject: |
| I already have the Direct X (March 2009) installed. |
| Back to top |
moonwalker
Posted: Thu Aug 20, 2009 8:55 am Post subject: |
i updated my profile info , hope that helps u help me . i also have latest directX .
Windows XP PRO SP3
Intel Core2 e6700
2.67ghz
Ga-965p-dq6 motherboard
2gb ddr2 memory
Geforce 7950 gx2 1gb
Seagate sata2 250gb 16m cache
250gig Hard drive
Pioneer dvr-111dbk dvd writer
LG HL-DT-ST_DVDRAM_GSA-H62N
LG HL-DT-STDVDRAM GSA-4120BA115
500 w power supply |
| Back to top |
sjj1805 Site Admin
Posted: Thu Aug 20, 2009 9:27 am Post subject: |
The only thing that concerns me is XP Service Pack 3, I had a few quirks after that
( see Anyone got a problem with XP SP3 and MSP8 ? )
At this time I can only suggest the text book answer and try a re-install of DVDWS 2 _________________ Regards, Steve Jones, Web Board Administrator
| Back to top |
Coral
Posted: Thu Aug 20, 2009 1:41 pm Post subject: |
| If you do a reinstall of DVD Workshop 2, try it first without the update patches. |
| Back to top |
moonwalker
Posted: Fri Aug 21, 2009 8:52 am Post subject: |
| sjj1805 wrote: | The only thing that concerns me is XP Service Pack 3, I had a few quirks after that
At this time I can only suggest the text book answer and try a re-install of DVDWS 2 |
ok thanks .
it worked fine with sp3 b4 , its just something thats happened for no doing of myself .
is it anything to do with overlay settings in Nvidia controll pnl ?
I will do a reinstall if it persists after i try a few over things . |
| Back to top |
sjj1805 Site Admin
Posted: Fri Aug 21, 2009 8:59 am Post subject: |
| moonwalker wrote: | ..........
ok thanks .
When a program that was previously working fine suddenly begins to misbehave then you have to investigate what has changed.
Think carefully about what has happed to your computer since the last time it worked OK.
Have you had a sudden loss of electricity causing an abnormal shutdown of the computer.
Have you installed any new software
Have you removed any.
have you installed any new hardware.
have you had any of those automated Windows Updates.
Please view the troubleshooting guide here _________________ Regards, Steve Jones, Web Board Administrator
| Back to top |
moonwalker
Posted: Sat Aug 22, 2009 8:29 am Post subject: |
| sjj1805 wrote: | | moonwalker wrote: | ..........
ok thanks .
Please view the troubleshooting guide here |
no none of the above .
i have my pc working in tiptop condition . and havent changed or unistalled or installed anything new or done any changes in any way .
i think to reinstall it may be the best thing to do . |
| Back to top |
