Bignosetw wrote:Dear all
Corel is pleased to announce the following:
All-in-One HD Creation is Here!
Ulead® DVD MovieFactory® 6 Plus (with HD Power Pack) is the first consumer DVD authoring software to support HD DVD, Blu-Ray Disc and AVCHD disc formats. Get video from HDV or AVCHD HD camcorders - or recorded HDTV programs. Output to Blu-ray Disc or HD DVD formats with full motion menus - including next-generation HD DVD Advanced (Type II) pop-up menus. Create HD discs using your standard DVD burner as HD DVD on Standard Definition DVD or AVCHD discs. The only complete all-in-one HD solution, Ulead DVD MovieFactory 6 Plus makes professional-looking HD results fun, easy & fast.
See the full details here:
http://www.ulead.com/dmf/plugin.htm
Tobie Openshaw
Manager: MarCom Dept
Corel Digital Media Solutions
LeeB99 wrote:I have been able to use this software to successfully create BDMV discs from my high definition archived content. Unfortunately, I have not been able to create a BDMV with working menus. The software spends about an hour "rendering" the MPEGS for the menus, and then aborts the procedure with "Unexpected Error" in a message box. The operation them terminates. And this is even after I used the "simulation" mode to test the menu before initiating the burn. Is there something that I am doing wrong (or not doing at all)? Without Menus, it works fantastic. When I add chapter stops, it does not effect playback at all. Also, it accepts 720p material without requiring a conversion process, and will burn both 720p and 1080i material to the same BDMV compilation.
One tip that I would like to share is that you must make sure that the hard drive that your "working folder" is assigned to has enough room to cache all of the information before the burn. Otherwise, you will get an error, and the program will stop the procedure...
Lee
dhnj wrote:I have only used HDV Mpeg2 footage from a Canon HV20 Camcorder.
You can insert .HDV hd-mpeg2.m2t (TS) video files.Does this new HD powerpack support M2T format now, or at least timestamp-based scene splitting for HDV tapes now?
That's my primary blocking point to buying DVDMF6+ or VS11+ ...
etech6355 wrote:You can insert .HDV hd-mpeg2.m2t (TS) video files.Does this new HD powerpack support M2T format now, or at least timestamp-based scene splitting for HDV tapes now?
Neither MF6+ or VS11+ captures in the TS format, they bothl capture in the PS format. and neither program splits by date/scene..
You can use HDVSplit to capture in the TS format & auto-split HDV, then insert into MF6+ or VS11+.
You need to buy the Plus versions for High Definition video.
Yes, without re-encoding if they are avc/h264 compliant for blu-ray disk.In BDMV mode does the Ulead DVD MovieFactory Plus 6 HD Power Pack only support MPEG 2 streams output, or will it include MPEG-4 AVC/H.264, as long as I give it proper files?
