How can I manipulate layers?
Postby siegeofmalta on Fri May 04, 2012 9:14 am
Hi everyone, I'm new to this board.
I have Paint Shop Pro X4 which I am using to try and manipulate images of postage stamps. I scan the stamp using a film/slide scanner and using the cmyk splitter can produce a good images of the watermark and postmark cancellation, which I save separately. On a lot of the older stamps the plate number, from which the stamp is printed, is engraved into the design of the stamp and quite often this number is obliterated by the black cancellation mark. Is there any way using layers, or any other X4 feature, I can lift the cancellation mark from the image to see what is underneath?
I have read a number of posts and I think this is a good useful board. It's a pity more people do not take advantage of it.
siegeofmalta
Re: How can I manipulate layers?
Postby hartpaul on Fri May 04, 2012 6:15 pm
I think what you would need to do is photograph the stamp under a light that makes the ink transparent.
Unless the image is captured in camera you cannot see what has not been captured .
Ie taking a photo of a car and and placing that in PSP X4 in layers will not allow you to open the boot / trunk and see what is inside,
motherboard: AsusTex P7P55D
ram: 2.99 Gb
Hard_Drive_Capacity: 2000 Gb
Postby siegeofmalta on Fri May 04, 2012 9:28 pm
Thanks for that hartpaul, I guess I have some experimenting to do!
Regards
siegeofmalta
Postby siegeofmalta on Mon May 07, 2012 11:45 am
hartpaul wrote:I think what you would need to do is photograph the stamp under a light that makes the ink transparent.
Hello hartpaul.
The ink is black Indian Ink I think. Any ideas as to which type of light or filter would work
Regards
siegeofmalta
Postby hartpaul on Mon May 07, 2012 7:18 pm
If the ink is black india ink then probably out of luck.
http://en.wikipedia.org/wiki/India_ink . India ink is essentially lampblack , (carbon) and only way to make carbon transparent is to turn it into diamond at high pressures and temperatures. If it is very thin, then the underlying inks may be made to flouresce - try a black light . ultraviolet light, Don't know what wavelength you would need however. Might be a lost cause apart from very carefullt abrading the india ink off which may damage what you are trying to preserve anyway.
ram: 2.99 Gb
Postby siegeofmalta on Tue May 08, 2012 8:09 am
hartpaul wrote:If the ink is black india ink then probably out of luck.
Thanks for your input hartpaul. It was good of you to take the time out to reply, even if I'm no further forward.
rgds
siegeofmalta
