First let me clarify that you're using MSP 8, on a Win7 computer?
In the preferences dialog (File menu>Preferences or pressing [F6] on you keyboard) you set the default duration. This is found on the
General tab toward the bottom
Default inserted clip duration, and is the number of
Frames. So I would guess yours has something like 50 frames (PAL) or for NTSC-60 frames. If you want the default duration longer, enter the number of frames or use the up/down arrows beside the entry box.
- msp8_def_clipduration.jpg (44.17 KiB) Viewed 1257 times
This will not affect clips already in the timeline. So you need to select all the clips in a track to change the duration of those clips..
- track_select_tool.jpg (32.13 KiB) Viewed 1257 times
With the Track selection tool, select the track which selects all the clips, then right-click on a clip and select Duration from the menu.
- duration_1.jpg (32 KiB) Viewed 1257 times
The Duration dialog will open, enter the duration.
NOTE in this dialog the format is H:M:S:F (hours, minutes, seconds, frames), where in the Preferences it just allows for the number of Frames..
- duration_2.jpg (20.79 KiB) Viewed 1257 times
