For those who haven't seen this series, without giving anything away, briefly a Detective Chief Inspector is involved in a Road Accident, when he 'awakes' he has travelled back in time to 1973 and is now a Detective Inspector.
The world then was a very different place to what it is now - No CCTV, No DNA, No Armed Response Units etc.
I was impressed by the DVD Menu employed with this boxed set, briefly you have a sheet of paper pinned to a wall with some boxes down the left and writing alongside those boxes. A red X signifies the chosen menu item.
I decided to try and recreate this menu and in fact found it was very simple and uses a combination of highlight images and hidden buttons.
Step 1: Start a Blank menu
Step 2: On the Menu Tab drag your image onto the menu so that it forms the background
Step 3: Drag a button onto the menu - any button will do because we will be hiding it later. Resize the button so that it is quite small - this is to prevent an overlapping button issue later.
Step 4: Create an image of a letter X using PhotoImpact. The X should be on a transparent background and then saved as a UFO file.
Here is one ready made for anyone who wants to give this a try
http://www.steve-jones.pwp.blueyonder.c ... rial/x.ufo
Step 5: Import the image into the DVD Workshop Highlight Images Library and then drag it onto the button created at step 3 above.
This has now associated the highlight image with that button.
Step 6: Drag the highlight image into position. It is also recommended that you show the button boundaries by clicking the 3rd button along at the bottom right of the preview screen.
Step 7: Use copy and Paste to duplicate the button the required number of times and then align the buttons and highlighted images into the required positions.
Step 8: Set the Color mapping of each button to RED/RED
Values are R - 196: G - 0: B - 0:
Step 9: Attach the required actions or playlists to each button
Such as chapter 1, chapter 2, Next, previous, Playall etc.
Step 10: Make each button invisible. Doing this will not hide the highlight images associated with the buttons.
Task completed now test your new DVD Menu.
