NEW! Corel PaintShop Pro 2018
VideoStudio Smart Compositions.
For VideoStudio, MediaStudio Pro, VideoGraphics Lab, Cool3D
Moderators: lata, Ken Berry
Postby sjj1805 » Wed Nov 01, 2006 2:17 am
I was hoping the topic title would grab your attention :D
MediaStudio has something termed a Smart Compositor Designer tool.
This enables MediaStudio users to create short special effect sequences that can then be dropped into a video project. The Video's and sounds within that sequence are then replaced by the end user with their own.
These sequences are elaborate effects often used as opening sequences, though they can be used anywhere in the video. Here is a short example:
There is no reason why VideoStudio Users cannot share their creations with other members of this forum. What you need to do is save the VideoStudio Project file and then make it available for other members of this forum.
1. Please identify which version of VideoStudio was used to create it. A Project file from an earlier version can be opened in a later version but not the other way round.
2. Use the "Smart Package" option to place all of the material together in one folder on your computer.
VideoStudio will automatically create a new vsp file for that project inside that new folder.
Please make a zip copy of the folder and share the zip file.
3. To share your projects you need to place the zip file on the internet somewhere and then place a link to it. Microsoft offer 25 GB of free storage known as Windows Sky Drive.
Unlike other free file sharing sites that suddenly disappear overnight, I think the storage facility by Microsoft is more reputable and likely to still be there next year!
Between us we can build ourselves a vast library of ready made routines ready to drop into our Home Movies. There are a few VideoStudio X3 Smart Projects below to get this thread started. Most of these were provided by the VideoStudio X3 Project Manager. Come on ladies and gents, I am sure there is some talent amongst you out there, it is time to show off your skills!
Shrinking a circle onto an item of interest.
Postby sjj1805 » Wed Nov 01, 2006 2:29 am
The first offering of our shared 'Smart Compositions' has been provided by forum member Trevor Andrew
http://uk.geocities.com/trevor.andrew@b ... circle.zip
This if for VideoStudio 9 (Or later)
Trevor's Instructions:
I just ran this process through VS 9 to create a shrinking circle.
This is what I did
Started new project
Add Green colour clip at 10 seconds
Add Black Colour clip At 10 sec.
Add transition at 10 sec ¡¥Wipe/Circle¡¦
Rendered to DV to create a Avi file. (called¡X1 green circle)
Start new project
Insert new Dv-Avi in timeline (1 green circle)
Cut last 2 seconds and delete, this retained my circle on screen.
Rendered to new DV-Avi (called it 2 green circle)
Placed the ¡¥2 green circle¡¦ in timeline in a new project (8 secs long)
Selected last frame in project mode, and from Tools-Save Current Frame as Image
Dragged Dv-Avi ¡¥2 green circle¡¦ in overlay track
Placed Image saved from above in overlay track, (7 secs) adjacent to dv-avi
Total length of project 15 secs.
Applied Chrome Key to both clips to remove green colour.
Placed my cat to the main timeline, which looks just like a football (I13.jpg), from the image library. Set to 6 sec.
Placed the cat clip again to overlay track for 9 secs.
Set Pan and Zoom for first image.
Pan from centre of frame to middle of ball.
Zoom to ¡VStart 112 end 150 ( these settings will require adjusting depending on the size of the image.)
Applied zoom to second image 150 start and end. (ticked the NO Panning box)
Render the project to Dv to produce the final video clip.
This should play much better than the project.
Add titles to the new video clip.
Result, the frame collapses to a small sized circle in the middle of the screen,
the image pans following the ball, keeping the ball in view.
The circle and image stay in view for a further 9 seconds¡X15 in all.
There may be many variations to this work flow, getting the circle to pan may be the next step.
Trevor
Title Overlay
Postby sjj1805 » Wed Nov 01, 2006 2:41 am
Here are some offerings by
Vidoman
and
Create your text in an image program like PhotoImpact, then save it as a *.png file. Your text should have a thick border, I used a 3 or 4 px border, and made the text color green. The background that your text is on, will be black. Then in VS place it on an overlay track, then set the chroma-key to the color of the center of your text, which in this case was green. Since you told VS that the transparency color is green, the black will cover the remainder of the screen.
Here's a couple of quick examples..
Example-1
Example-2
Example-4
Example of Black Lab's Method, SWF format
Black Lab's Method WMV format
In Example-4, I used the video file behind, and on top of the text/image file, and then used the title. The last few seconds shows just the text/image with the video file showing through. I also noticed that for some reason Putfile wants to stretch the video...
Quality is poor due to size, and done rather quickly...
@BlackLab
Another way to do it, just by using VideoStudio, is to use what is called an Intermediate Render.
In a new project create your title. Use black as your font color, with another color as the outline. (NOTE: if you just want a transparent title over your video then the color you use for the font has to be the same color you have designated to be the background color under File>Preferences>General Tab - in my case it is black. For a different effect use a font color that is different from your background color.)
When your clip is complete, choose Share>Create Video File. Put that new video file of your title in an Overlay track. With that clip selected, choose the Attribute tab and click on the Mask & Chroma Key button. Check the Apply Overlay Options box, make sure Chroma Key is the type selected, and choose black (or the color you used) as the keyed color. The font color, as well as the background, will then become transparent, showing the video in the main track thru your title.
Split Screen Effect - VideoStudio 10
Postby sjj1805 » Wed Nov 01, 2006 2:48 am
I used only sample clips installed with VS10+, not very fancy just an attempt to show how to make two clips do a "Kiefer Sutherland 24" effect.
Didnt have much time to get it all perfect as I am busy trying to edit my recent holiday video & pictures, but this works:
http://www.steve-jones.pwp.blueyonder.c ... s10pip.VSP
Circlular PIP for VS9 & VS10
Postby sjj1805 » Mon Nov 06, 2006 9:01 pm
This project will work with VideoStudio 9 and also VideoStudio 10+
If you have both versions then you only need to download file 1 "circlesVS9.zip".
If you only have VideoStudio 10+ then you also need to download file 2 "circlesVS9videos.zip" containing the sample videos which have been taken from VideoStudio 9.
http://www.mediamax.com/sjj1805/Links/69A67D6848
This project is based upon the following Tutorials and puts them all together to show
1. How to create a circular picture in picture effect
2. How to use a VideoStudio Project in the overlay track
3. How to use transitions in the overlay track.
The important thing is to make sure you unzip everything to the correct location.
The files in file 1 "circlesVS9.zip" should create files on your hard drive as follows:
C:\projects\circlemask.tif
C:\project\vs9circles01.vsp
C:\projects\vs9circles02.vsp
The files in file 2 "circlesVS9videos.zip" should create files on your hard drive as follows:
C:\Program Files\Ulead Systems\Ulead VideoStudio 9.0\Samples\Video\v12.avi
C:\Program Files\Ulead Systems\Ulead VideoStudio 9.0\Samples\Video\v13.avi
C:\Program Files\Ulead Systems\Ulead VideoStudio 9.0\Samples\Video\v14.avi
Please only download these files if you don't have them already.
My MediaMax account allows me to share 1GB of downloads per month which means that everytime somone downloads a file a piece of the 1GB is used up.
With all your files in place you open VideoStudio and then open
c:\projects\vs9circles02.vsp
The project file vs9circles01.vsp is what has been placed onto the overlay track. This highlights how you can place transitions, cuts and so forth onto an overlay track.
Re: VideoStudio Smart Compositions.
Postby sjj1805 » Sun Aug 22, 2010 1:18 am
Return to VIDEO Product Tutorials
Who is online
Users browsing this forum: No registered users and 2 guests
