Movie Factory 7SE and don't want smart titles
Postby cdoughertycd on Fri Nov 11, 2011 8:54 am
MF 7SE forces me to use smart titles. I want to use my own jpeg for title background. I end up having to delete smart title text boxes by moving them out of the field or in some cases I can get a "hide object" but not all the time. Is there a blank title background I can use to put my own jpegs on?
cdoughertycd
motherboard: Intel DG43GT PCIE
processor: 3.07 gigahertz Intel Core 2 Duo
ram: 6 GB
Video Card: Intel built in
sound_card: Intel High Definition Audio HDMI - Realtek Hi Def
Hard_Drive_Capacity: 640.04 GB
Re: Movie Factory 7SE and don't want smart titles
Postby BrianCee on Fri Nov 11, 2011 4:49 pm
Well - - I am not sure how 'special' your SE (Special Edition) version is - but in the standard version after you have loaded your videos into the timeline you click "Next" - this takes you to the next window where you select your menu template - at the top of the selection previews on the left are two tabs and a drop down . The drop down should allow you to select alternative types of pre-installed menus such as thumbnails or text. The two tabs are marked 'Gallery' and 'Edit' - by default you are on gallery so click on 'Edit' - you should now be presented with options to change the background music - or change the background picture - plus a whole host of other modifications. If you use the 'customise' option and make changes you will then get the option (under the preview window) to save that menu as a template for future use - or as a base for further changes.
BrianCee
Postby cdoughertycd on Fri Nov 11, 2011 8:22 pm
Brian, in my MF 7SE my "add template menu" in Customize is grayed out, but my issue is prior to that, to build the template without all the smart template stuff I don't like, using my own jpg, I have to move or hide the smart template designs, just wishing there was a selection that did not include smart designs. It forces me to select something from the Gallery.
I'm having a problem burning it anyway due to just recent issue that comes up when the burn is almost done, error says "unspecified error". I have this question in another post. My DirectX and video card drivers are up to date, anyway ...maybe I should get MF 7, like buy it. MF 7SE was offered free to Pro X3 users when the program for burning with it wasn't working.
Candy
cdoughertycd
ram: 6 GB
Postby BrianCee on Sat Nov 12, 2011 1:45 pm
I am wondering whether my response in this topic here :-
viewtopic.php?f=2&t=44060&start=0
is any help to you with your title issue.
BrianCee
Postby cdoughertycd on Sun Nov 13, 2011 1:48 am
Brian, thanks for your help, I went to that thread and posted a couple of questions for Abiel.
cdoughertycd
ram: 6 GB
Return to DVD MovieFactory
