CUDA vs Sandy Bridge onboard graphics
Postby Steve-o on Thu May 17, 2012 2:05 pm
I have a Sandy Bridge (Z68) based system where I run my Video Studio....using an i5 processor. It has onboard graphics which are generally enough for everything I need.
Will I get significantly faster processing if I buy an Nvidia graphics card with CUDA enabled. eg a 550 or similar. This will run $150 to $200. It is worth the investment in the sense that I will see a big jump?
Steve-o
Re: CUDA vs Sandy Bridge onboard graphics
Postby DVDDoug on Thu May 17, 2012 5:45 pm
I really don't know, but I doubt it... Probably some functions will speed-up a bit... Maybe some "little things" will speed-up a lot.
Are you using 100% of your CPU(s) now? I think the hard drive(s) (and perhaps the data bus) are usually the bottleneck. You can't render any faster than you can read/write the files. ;)
If you don't already have a 2nd drive, that might speed things up more. If you read from one drive and render to another, the drive doesn't have to alternate between reading & writing. For example, you can usually copy a big file from one drive to another about twice as fast as making a copy on the same drive (a small file might copy faster on a single drive).
Head over heels,
No time to think.
It's like the whole world's
Out of... sync.
DVDDoug
Postby erdna on Thu May 17, 2012 9:10 pm
The question on the gain significance with CUDA GPU and VSX4 is difficult two answer, Nobody seems to know how "deep" the Corel programmers have linked the program into the CUDA co-processing. Afaik their are no benchmarks for VS available. It will certainly do somthing(I think..). Of course we all know that programming a very small bit in the CUDA processor, allows you to commercialy declare that you have CUDA support in your program.
erdna
Postby Steve-o on Fri May 18, 2012 1:19 pm
DVDDoug - yes CPU is running close to 100%.
I already have two hard drives - 3 if you count SSD for the system drive.
My choice is to try a CUDA enabled card or upgrade to an i7. The card would be $150 to $200, but an i7 will be around $300.
Steve-o
Postby lilu_hotty on Fri May 18, 2012 4:35 pm
1st of all i5 - is kind of junky! the lack of Hyperthreading in most models - talks for its self !!! and its not good for video editing ! So changing CPU its self will give some extra power for sure
about the cuda Corel told me its best to use.....so,-
WIN7 Pro 64bit SP1, VS Pro X4 SP2, Drive C-WD Raptor, Intel i7 950 3.07, MSI X58m, ATI HD4890 1GB, Realtec HD audio, 6GB DDR3 RAM, Sata II-6HDDs
Panasonic AF101, 1080 25P, Lumix 25mm f1.4, sigma 18-50 f2.8, Rode Ntg2, SDHC SanDisk Extreme 30mb/s 32GB
lilu_hotty
motherboard: MSI X58m
processor: Intel I7 950 3.07 GHz
ram: 6GB
Video Card: ATI HD4800 1024mb
Hard_Drive_Capacity: 6TB
Monitor/Display Make & Model: HP w2207h
Postby teknisyan on Sat May 19, 2012 12:43 pm
VS X5 have been optimized to take advantage PC with GPU and multi-core acceleration. I do not have a CUDA GPU but I can tall you VS X5 render faster than the old videostudio.
There have been no official bench mark how big the speed bump will be once you get a CUDA GPU but I'm sure people who are using VS X5 with CUDA GPU can vouch for me.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
teknisyan
processor: Intel Corel i5
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Postby 3deeguy on Sat May 19, 2012 11:36 pm
I don t know if you read any of my posts but I am close to 1 hr rendering 1 hr 3D HD into MP4 3D HD. Read my posts for the full description of my system
3deeguy
3deeguy
motherboard: gatewayfx6860
processor: intel i7
ram: 16 gig
Video Card: nvidia gtx560ti
sound_card: don t know
Hard_Drive_Capacity: 2 terabyte
Monitor/Display Make & Model: hp 2011
Postby pepegota on Mon May 21, 2012 3:58 pm
With early Sandy Bridge computers (H67) the Quick Sync function only works with on board graphics. Later versions (P68) have eliminated this constraint.
pepegota
motherboard: Asus P8H67 M EVO
processor: Sandy Bridge
Video Card: Intel on board graphics
sound_card: Sound Blaster
Hard_Drive_Capacity: 600 GB
Monitor/Display Make & Model: Samsung, 19" LCD
Postby lilu_hotty on Mon May 21, 2012 5:34 pm
pepegota wrote:With early Sandy Bridge computers (H67) the Quick Sync function only works with on board graphics. Later versions (P68) have eliminated this constraint.
there is just no way that on board grafic will be better then a separate proper video card.
when i look at that new - 3rd generation - its seems to me that its a Budget design..... i dont think 4 cores with on board grafic, will be faster then 6 cores with a cuda GPU...... i just cant believe it.
would like to see a real word comparison !
lilu_hotty
ram: 6GB
Postby lilu_hotty on Mon May 21, 2012 5:46 pm
Abiel Corel NA wrote:There have been no official bench mark how big the speed bump will be once you get a CUDA GPU but I'm sure people who are using VS X5 with CUDA GPU can vouch for me.
For me its not only how much faster the rendering can be - if say true i don care - with Cuda card used, but how smooth i can go back and forward in the time line how many sec i need to wait if i jump from 1 frame to another . thats what really drives me crazy when i work with AVCHD files ....... i hope these issues will gone after i get the Cuda card
also it can probably improve the quality as the newer cards have 10bit per color..... and improve some of the things....
lilu_hotty
ram: 6GB
Postby pepegota on Tue May 22, 2012 3:10 pm
Sorry but, it's true. H67 without video card faster than H67 with video card.
<<And the only reason why a given Sandy Bridge system is faster with QuickSync and integrated Intel graphics than an otherwise identical system with a discrete Nvidia graphics card is because the H67 chipset gimps the PCIe-x16 graphics card slot: That slot only runs in PCIe-x1 mode instead of the correct x16 mode by default. Otherwise, a P67-based system with a discrete Nvidia GPU far outperforms the H67 setup with integrated Intel graphics.>>
The obvious is sometimes not obvious. Fact is better than phantasy.
pepegota
Postby Steve-o on Wed May 30, 2012 8:30 am
lilu_hotty wrote:i hope these issues will gone after i get the Cuda card
[/quote]
If you do get a CUDA card be interested to see the difference - both in trans-coding and your observation about scrolling.
Steve-o
Users browsing this forum: Google Feedfetcher, weaver and 7 guests
